https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> extract PinList from layout https://designers-guide.org/forum/YaBB.pl?num=1216996317 Message started by avlsi on Jul 25th, 2008, 7:31am |
Title: extract PinList from layout Post by avlsi on Jul 25th, 2008, 7:31am Not all Pins are getting shown by using this command schLayoutToPinList. Any idea? |
Title: Re: extract PinList from layout Post by Andrew Beckett on Jan 3rd, 2009, 12:07am I had a look at the code for this function (I work for Cadence), and I can't see how it could omit any pin - it looks at all the terminals in the cellView. Are you sure all the pins really were pins? (i.e. they weren't just shapes with text labels above them). If you do: Code:
It will list all the terminals in the current cellView. Regards, Andrew. |
