https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> RF power measurement https://designers-guide.org/forum/YaBB.pl?num=1219399558 Message started by rf4Tmen on Aug 22nd, 2008, 3:05am |
Title: RF power measurement Post by rf4Tmen on Aug 22nd, 2008, 3:05am Dear all, I'm using goldenGate to simulate and measure the output power of power amplifier versus the SWR. I'm looking for the fashion which 'll help me to measure the reflected power du to the variation of the antenna impedance and to separate it from the incident power. In other word to emulate a directional couplers. Someone has an idea? Thanks to all. |
Title: Re: RF power measurement Post by nano_RF on Aug 24th, 2008, 9:42am Hi, I have never done this, but just wondering if you can use ideal coupled line structure from ADS library to create say 20 dB directional coupler, and can measure incident power and reflected power. Regards |
Title: Re: RF power measurement Post by pancho_hideboo on Aug 24th, 2008, 5:32pm rf4Tmen wrote on Aug 22nd, 2008, 3:05am:
If you mean Agilent GoldenGate Simulator, an ideal circulator is available in goldenGateLib as CIR3. Also isolator(ISO) and gyrator(GYR) are available in goldenGateLib. Without usigng goldenGateLib, you can describe circulator, isolator and gyrator using Verilog-A. nano_RF wrote on Aug 24th, 2008, 9:42am:
In Agilent GoldenGate, we can't use any ADS Library component. Instead, we have to use goldenGateLib or Verilog-A. |
