Measurements >> RF Measurements >> NF measurement using noise source
https://designers-guide.org/forum/YaBB.pl?num=1221172918
Message started by karen on Sep 11th, 2008, 3:41pm
Title: NF measurement using noise source
Post by karen on Sep 11th, 2008, 3:41pm
Hello,
I am using HP346A noise source to measure the receiver chain noise figre. That is a ZIF system. I switch on/off the noise source, measure the output noise difference, do the calculation, I got the NF.
Do I need to subtract 3 dB from the calculation?
thanks.
k : :-[
Title: Re: NF measurement using noise source
Post by Mazz on Dec 26th, 2008, 12:54am
In case of ZIF systems the NF is DSB (double sideband) so you don't need to subtract 3dB.
Mazz
