https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> Passing bit width in module parameter instance definition in nc-verilog https://designers-guide.org/forum/YaBB.pl?num=1233772404 Message started by SG on Feb 4th, 2009, 10:33am |
Title: Passing bit width in module parameter instance definition in nc-verilog Post by SG on Feb 4th, 2009, 10:33am Hi, I have been using verilog-xl so far and have got my code compiled in the format where I use the same module with different bit-widths and get it compiled. For eg, quantizer #(32,16) quant1(out,in) I now need to generate some annotation files using nc-verilog and hence, when I compile the same in it, it gives me an error, with the "#(32,16)" part: Too many module instance parameter definitions. Is it possible to make nc-verilog read the above statement without having several copies of the same module in my code ? Thanks for you help, Shubh. |
