https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Accuracy of PNOISE analysis https://designers-guide.org/forum/YaBB.pl?num=1234906984 Message started by SiValley_designer on Feb 17th, 2009, 1:43pm |
Title: Accuracy of PNOISE analysis Post by SiValley_designer on Feb 17th, 2009, 1:43pm I'm simulating the phase noise of an LC-VCO. Sometimes I get the following warning: PSS analysis may be insufficiently accurate for PNOISE analysis. Consider tightening simulation tolerance. I have tried reducing reltol, vabstol, and iabstol to much smaller values than recommended by the manual but nothing changed. I searched previous threads but in the only relevant one the issue was sweeping frequencies all the way down to zero thus creating flicker-noise related issues. I'm only looking at above 1kHz and I have turned off all flicker noise sources of active devices. Amy ideas on how to get rid of these warnings? Thanks, |
Title: Re: Accuracy of PNOISE analysis Post by pancho_hideboo on Feb 18th, 2009, 4:58am Your post is no more than usage of specific EDA vendor's simulator. There is no Design issue. Please post to "The Designer's Guide Community Forum ≫ Simulators ≫ RF Simulators". SiValley_designer wrote on Feb 17th, 2009, 1:43pm:
So you have to make it clear what vendor's simulator you use. If you use Spectre, which solver do you use in PSS or QPSS, Shooting_Newton or HB ? SiValley_designer wrote on Feb 17th, 2009, 1:43pm:
If you use HB, how do you set max harmonics and oversample_factor ? |
Title: Re: Accuracy of PNOISE analysis Post by SiValley_designer on Feb 18th, 2009, 10:05am Thanks for your response. I'm using Spectre so I run PSS followed by PNOISE to simulate phase noise. I believe because I'm using Spectre PSS, the solver is Shooting_Newton. The parameters you have referred to are calculated automatically by Spectre based on analog options. In terms of maximum number of sidebands and also tstab I believe they are large enough because further increase in them does not change anything. |
Title: Re: Accuracy of PNOISE analysis Post by pancho_hideboo on Feb 18th, 2009, 7:00pm SiValley_designer wrote on Feb 18th, 2009, 10:05am:
Show me your portions of netlist regarding analysis statements(PSS and Pnoise) and options statement. |
Title: Re: Accuracy of PNOISE analysis Post by SiValley_designer on Feb 18th, 2009, 7:11pm Here is my simulation command: simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \ sensfile="../psf/sens.output" checklimitdest=psf dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status dcOpInfo info what=oppoint where=rawfile pss ( Out Outb ) pss fund=18G harms=80 + errpreset=conservative tstab=100n skipdc=no method=gear2only + tstabmethod=gear2only annotate=status pnoise ( Out Outb ) pnoise relharmnum=1 start=1k + stop=100M dec=20 maxsideband=80 annotate=status modelParameter info what=models where=rawfile element info what=inst where=rawfile outputParameter info what=output where=rawfile designParamVals info what=parameters where=rawfile primitives info what=primitives where=rawfile subckts info what=subckts where=rawfile saveOptions options save=selected pwr=none |
Title: Re: Accuracy of PNOISE analysis Post by pancho_hideboo on Feb 18th, 2009, 7:45pm SiValley_designer wrote on Feb 18th, 2009, 7:11pm:
If this too extraordinarily tight netlist is true netlist you use, show me log file of Spectre corresponding to this netlist. There are some people who show fake netlists in this Forum. |
Title: Re: Accuracy of PNOISE analysis Post by SiValley_designer on Feb 18th, 2009, 8:02pm Here is the log file. I removed part of the preamble for confidentiality reasons. There are many breakdown warnings, which I'm sure are not the reason for PNOISE failure (I have other simulations without such warnings and yet they give the warning regarding PNOISE accuracy). The PSS command used in this simulation is: simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \ sensfile="../psf/sens.output" checklimitdest=psf pss ( Out Outb ) pss fund=15G harms=80 + errpreset=conservative tstab=100n skipdc=no method=gear2only + tstabmethod=gear2only annotate=status tstart=20n pnoise ( Out Outb ) pnoise relharmnum=1 start=10k + stop=100M dec=20 maxsideband=80 annotate=status |
Title: Re: Accuracy of PNOISE analysis Post by pancho_hideboo on Feb 19th, 2009, 5:00am SiValley_designer wrote on Feb 18th, 2009, 8:02pm:
Three different fundamental frequencies exist in your log file. Fundamental frequency is 13.9102 GHz. Fundamental frequency is 13.9101 GHz. Fundamental frequency is 14.3745 GHz. If the above analysis statements are true, why do three different fundamental frequencies exist ? Show true netlist and log file. You should use HB solver not Shooting_Newton. http://www.designers-guide.org/Forum/YaBB.pl?num=1228240587/14#14 15GHz x 80=1200GHz. Holding noises from 1200GHz are nonsence. |
Title: Re: Accuracy of PNOISE analysis Post by Andrew Beckett on Feb 19th, 2009, 6:55am I would assume some sort of sweep is being done (perhaps via the parametric analysis tool?) which could explain why the netlist shows a single analysis, but the log has several. For a 15GHz (ish) oscillator, 80 harmonics seems rather excessive. Perhaps that's why it is struggling with accuracy - it thinks that the PSS solution is not accurate enough at higher harmonics (I'm guessing here). What kind of oscillator is it - that would govern the choice of HB or shooting? That said, you're not going to have massing amounts of harmonic content if it's a 15GHz oscillator, so shooting is unlikely to give you much advantage. Regards, Andrew. |
