https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Generate data with jitter https://designers-guide.org/forum/YaBB.pl?num=1234925581 Message started by littlepig on Feb 17th, 2009, 6:53pm |
Title: Generate data with jitter Post by littlepig on Feb 17th, 2009, 6:53pm Hi all, It there a way to generate input data stream with the effect of jitter.. I am currently running with Spectre.. Thanks.. |
Title: Re: Generate data with jitter Post by Andrew Beckett on Feb 17th, 2009, 7:57pm What kind of simulation are you aiming to do? The answer is somewhat dependent on that - it may be that a simple small-signal noise source is sufficient (if doing, say, pnoise analysis) - or you may need a larger-signal source for doing transient. Or you may be doing transient noise? I think some more details are needed before an answer can be given. Thanks, Andrew. |
Title: Re: Generate data with jitter Post by littlepig on Feb 17th, 2009, 9:55pm I am trying to do stressed-eye simulation.. It is for high speed digital communication.. |
Title: Re: Generate data with jitter Post by Andrew Beckett on Feb 18th, 2009, 12:59am I'm not familiar with a "stressed eye" simulation. I've found a few casual references to it from a google search, but didn't have time to research it fully to understand what you mean (I can guess, but I'd sooner know exactly what you mean). Can you point me at some references so I can understand precisely what you're trying to do? Or if not, explain it here? Regards, Andrew. |
Title: Re: Generate data with jitter Post by littlepig on Feb 18th, 2009, 10:38pm In optical communication, the receiver signal is corrupted. Stressed-eye diagram is the eye diagram acquire by the worse case input signal that is likely to happen in the system. |
Title: Re: Generate data with jitter Post by pancho_hideboo on Feb 19th, 2009, 6:13am littlepig wrote on Feb 18th, 2009, 10:38pm:
http://cp.literature.agilent.com/litweb/pdf/ads2008/ccsrc/ads2008/VtPRBS_(Time-domain_Pseudo-Random_Bit_Sequence_Voltage_Source).html http://cp.literature.agilent.com/litweb/pdf/ads2008/examples/SignalIntegrity/VtPRBS_prj.html You can create PRBS with jitters similar to the above by Verilog-A. |
Title: Re: Generate data with jitter Post by littlepig on Feb 19th, 2009, 9:09am Thanks for the help.. Is there any guide to write it in VerilogA? I am not familiar with VerilogA.. |
Title: Re: Generate data with jitter Post by pancho_hideboo on Feb 19th, 2009, 2:05pm littlepig wrote on Feb 19th, 2009, 9:09am:
And the followings are useful although they are VHDL-AMS. http://www.designers-guide.org/Modeling/JTOL_rev1.0.pdf http://www.designers-guide.org/Modeling/fc_jtol_src_ns.vhd |
Title: Re: Generate data with jitter Post by littlepig on Feb 19th, 2009, 5:00pm Thanks.. |
Title: Re: Generate data with jitter Post by Ken Kundert on Feb 19th, 2009, 6:12pm You might also want to take a look at the models that generate jitter in http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf -Ken |
