Simulators >> AMS Simulators >> multithreading enabled for spectre in AMS?
https://designers-guide.org/forum/YaBB.pl?num=1235165501
Message started by raftman on Feb 20th, 2009, 1:31pm
Title: multithreading enabled for spectre in AMS?
Post by raftman on Feb 20th, 2009, 1:31pm
Is it possible to enable the multithreading option for spectre while running through AMS (ncsim)?
I've tried including the -mt option under 'additional parameters' in simulator options with no success.  The documentation doesn't mention enabling multithreading, so i'd just like a confirmation that it isn't supported in AMS.  I presume it's because of the synching between the analog and digital solvers.
thanks!
Title: Re: multithreading enabled for spectre in AMS?
Post by Andrew Beckett on Feb 20th, 2009, 11:41pm
This is now supported in IUS82 (IUS8.2s-003). It's covered in a sourcelink.cadence.com solution, number 11532410.
Regards,
Andrew.
