Measurements >> Other Measurements >> Filter testing
https://designers-guide.org/forum/YaBB.pl?num=1239428822
Message started by manodipan on Apr 10th, 2009, 10:47pm
Title: Filter testing
Post by manodipan on Apr 10th, 2009, 10:47pm
Dear all,
I want some good reference on testing filters....all sorts of measuremnts like two tone testing etc..also method of converting single ended to differential voltage converter at the input.............then how to take the outputs off chip ,what sort of buffer to be used??
Thanks a  lot..
regards,
Manodipan
