https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> How to know current origin in Cadence Virtuoso Symbol Editor ? https://designers-guide.org/forum/YaBB.pl?num=1241258651 Message started by pancho_hideboo on May 2nd, 2009, 3:04am |
Title: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by pancho_hideboo on May 2nd, 2009, 3:04am I can set an origin in Virtuoso Symbol Editor. However I can't find a method to know where current origin is located. How to know current origin in Cadence Virtuoso Symbol Editor ? Any expert of Cadence Tools, teach me. |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by Andrew Beckett on Jul 10th, 2009, 8:45am Pancho, Sorry about the delay. Been a tad busy the last few weeks. Anyway, in the Symbol Editor go to Options->Display and turn on "Coordinates on Status Banner". You'll then see the coordinates as you move your cursor. 0,0 is the origin. You can do Edit->Origin to move the origin (actually everything moves if you do this). Best Regards, Andrew. |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by pancho_hideboo on Nov 24th, 2009, 3:32am By setting "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on" manually, I can show coordinate information in Symbol Editor. However I would like to this as default setting. So I write the following in ".cdsinit". envSetVal( "schematic" "statusBannerXY" 'boolean t ) But this does not work. Maybe kewords such as "schematic" and "statusBannerXY" are improper. How should I write to set "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on". Any expert of Cadence Tools, teach me. |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by oermens on Nov 24th, 2009, 5:31am In your .cdsenv try adding the following: schematic statusBanner boolean t schematic statusBannerXY boolean t |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by pancho_hideboo on Nov 24th, 2009, 5:37am oermens wrote on Nov 24th, 2009, 5:31am:
I already have the following in ".cdsinit". envSetVal( "schematic" "statusBannerXY" 'boolean t ) I will try add the following in ".cdsinit". envSetVal( "schematic" "statusBanner" 'boolean t ) |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by pancho_hideboo on Nov 27th, 2009, 2:12am oermens wrote on Nov 24th, 2009, 5:31am:
So even if I set following two, still I can't set "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on". schematic statusBanner boolean t schematic statusBannerXY boolean t How should I write to set "Schematics > Options > Display : Coordinates_on_Status_Banner" as "on". Any expert of Cadence Tools, teach me. |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by Andrew Beckett on Jan 4th, 2010, 9:13am Pancho Hideboo, You have to use the function: schChangeStatusBanner("xy") I suspect this is for some strange historical reason - probably predating cdsenv settings... It seems that the form sets the cdsenv setting based on which banner is in place (the other value is "default"). Ah, I found a CCR about this, asking for this to be made public - CCR 78112 - and it seems the original reason was for performance - it was expensive to have to keep consulting the cdsenv setting (even in memory) every time the cursor was moved. Apparently it does work if you use a .cdsenv file (I didn't check), and so this workaround SKILL function is only needed if you want to do it via SKILL rather than via a .cdsenv file. Regards, Andrew. |
Title: Re: How to know current origin in Cadence Virtuoso Symbol Editor ? Post by pancho_hideboo on Jan 7th, 2010, 1:46am Andrew Beckett wrote on Jan 4th, 2010, 9:13am:
schChangeStatusBanner() can work as schChangeStatusBanner("xy") for "on", and as schChangeStatusBanner("") for "off". |
