https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> invoking a perl script from ncverilog? https://designers-guide.org/forum/YaBB.pl?num=1242168569 Message started by joel on May 12th, 2009, 3:49pm |
Title: invoking a perl script from ncverilog? Post by joel on May 12th, 2009, 3:49pm Hi All, My simulation needs to periodically regenerate its stimulus file based on current simulation conditions. I have a perl script that generates the stimulus file based on a few parameters. Is there a simple way to invoke a perl script from an ncverilog simulation and suspend the simulation until the perl script completes? e.g. always #10000 begin $system("create_stim_file.pl"); $readmemh( "stim_file.dat", stim_data); end I've glanced at the PLI and VPI docs, but it seems overkill and very complex for my goal. Thanks, -Joel |
Title: Re: invoking a perl script from ncverilog? Post by joel on Jun 1st, 2009, 12:17pm Hi All, I guess I'm the only one doing this! But just in case anyone else is interested, here is what the Cadence AE said. Bracketing the $system call with $display statements will define its location in the event queue. So if you put this in your primary clock loop: $display("about to..."); $system("create_stim_file.pl"); $display("done..."); and make sure to stop your clock oscillator or whatever time-progression mechanism your sim uses while the three lines are being executed. Cheers, /jd |
