https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to verify Stability of Total Circuits ? https://designers-guide.org/forum/YaBB.pl?num=1243078889 Message started by pancho_hideboo on May 23rd, 2009, 4:41am |
Title: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 23rd, 2009, 4:41am We use loop gain evaluation method for stability analysis of amplifier having clear feedback. However what method do you use for verify stability of fairly large system circuits like MIMO(Multiple Inputs and Multiple Outputs). There are many feedback loops. And we can't find out all possible feedback paths. Agilent GoldenGate provides following two methods to perform Stability Analysis for judging whether the circuit is potentially stable or unstable. Nyquist Diagram : With this method, the circuit equation is solved at each point of a frequency sweep that goes from DC to a very high value. A Nyquist diagram is then created from this sweep and its analysis gives the value of the stability flag. The list of frequencies is also derived from the diagram. Eigenvalue Computation : With this method, the eigenvalues of a matrix that represents the circuit are computed. The stability flag and the list of frequencies are computed by the analysis of those values. So I tried this stability analysis of "Eigenvalue Computation" for post layout simulation using "extracted view". However this analysis results didn't report any unstable mode while actual chip shows remarkable parasitic oscillation especially for bias circuits. Transient Analysis(both traponly and gear2only) of Cadence Spectre don't show any remarkable oscillation. Envelope Transient Analysis of Agilent GoldenGate also don't show any remarkable oscillation, here waveforms of this result are completely same as results of Transient Analysis of Cadence Spectre. On the other hand, Transient Analysis(gear2) of Agilent GoldenGate show remarkable oscillation which is relatively close to actual phenomena. What method do you use to verify stability of fairly large system circuits ? |
Title: Re: How to verify Stability of Total Circuits ? Post by buddypoor on May 23rd, 2009, 5:26am pancho_hideboo wrote on May 23rd, 2009, 4:41am:
Indeed, you have mentioned a problem of principle nature. Of course, one can simulate or measure if a system is BIBO-stable or not by inspecting the output for different input signals (step, sinus,....). However, it is a problem to define something like a stability figure or a stability margin , because in this case you need an open loop function. But, when we have n loops - which loop is selected to plot its gain ? For my opinion, the classical stability criterion (Nyquist) cannot be applied in this case. |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 23rd, 2009, 5:52am buddypoor wrote on May 23rd, 2009, 5:26am:
because "1+G(s)" is identical to "Characteristic Polynomial" based on State Space Formulation. Here "G(s)" means OLTF(Open Loop Transfer Function). http://en.wikipedia.org/wiki/State_space_representation http://en.wikipedia.org/wiki/Nyquist_stability_criterion However I chose "Eigenvalue Computation" method not "Nyquist Diagram". In "Eigenvalue Computation" method, roots of "Characteristic Polynomial" based on State Space Formulation are evaluated directly. |
Title: Re: How to verify Stability of Total Circuits ? Post by thechopper on May 23rd, 2009, 10:58am Hi Pancho, Despite the method you use for analyzing stability - I usually use Nyquist for most of feedback systems I deal with - if the transient simulation is not showing any clue of instability while actual silicon does, you should start thinking the modelling of your parasitics might not be good enough, since transient analysis should reflect the actual stability condition of the system.... Regards Tosei |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 23rd, 2009, 11:12am HdrChopper wrote on May 23rd, 2009, 10:58am:
Results of Transient Analysis are very affected by initial conditions or startup conditions. This is very true for weak parasitic oscillation. http://www.designers-guide.org/Forum/YaBB.pl?num=1234428781/7#7 I used same initial conditions and startup pulse(voltage supply rampup) for Cadence Spectre and Agilent GoldenGate. Transient Analysis(both traponly and gear2only) of Cadence Spectre don't show any remarkable oscillation. Envelope Transient Analysis of Agilent GoldenGate also don't show any remarkable oscillation, here waveforms of this result are completely same as results of Transient Analysis of Cadence Spectre. On the other hand, Transient Analysis(gear2) of Agilent GoldenGate show remarkable oscillation which is relatively close to actual phenomena. I suspect that treatments during initial phase are different between Cadence Spectre and Agilent GoldenGate. If circuits are in very critical "Conditionally Stable State" at DC operation points, behavior during initial phase is very important regarding whether circuits show oscillation or not. http://www.designers-guide.org/Forum/YaBB.pl?num=1190272820 I can set very unstable conditions by decreasing decoupling capacitor value. When I create very unstable conditions, both Cadence Spectre and Agilent GoldenGate give same oscillation waveforms. |
Title: Re: How to verify Stability of Total Circuits ? Post by thechopper on May 23rd, 2009, 8:55pm pancho_hideboo wrote on May 23rd, 2009, 11:12am:
True. But this also might be the reason why when you run your stability analysis you did not see any aparent unstabilty...most probably actual initial conditions where not properly set as actual measurements are showing. If your system stability is so highly dependent on the intial conditions you should make sure the initial conditions at which you simulate your system are replicated in the actual circuit by same sort of start up circuit to guarantee stability... Tosei |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 23rd, 2009, 9:31pm HdrChopper wrote on May 23rd, 2009, 8:55pm:
As conclusion, there is no general and almighty method for verification of stability of fairly large system circuits including parasitics. |
Title: Re: How to verify Stability of Total Circuits ? Post by buddypoor on May 24th, 2009, 1:31am pancho_hideboo wrote on May 23rd, 2009, 5:52am:
Hi, pancho_hideboo. One question regarding your response: What is the "open loop transfer function" in a multloop system ? I suppose, in this case we have several "open loop transfer functions", donīt we ? And which one dominates ? This is - as far as I know - still an open question not answered in books on control theory. buddypoor |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 24th, 2009, 1:40am buddypoor wrote on May 24th, 2009, 1:31am:
However we can evaluate "Characteristic Polynomial of Matrix A" like following. ΦA(s)=det(s*I-A) http://en.wikipedia.org/wiki/State_space_representation We can apply "1+G(s)" type Nyquist Diagram concept to this ΦA(s). Here we look whether a locus encloses origin or not instead of -1+j0. |
Title: Re: How to verify Stability of Total Circuits ? Post by buddypoor on May 24th, 2009, 3:25am Hi pancho-hideboo, Yes, I agree with you. As described by you it is possible to check if the system is stable or not. However, as indicated in my first reply (23rd of May) my doubts were and are related to the definition of a reasonable parameter which can be used as a stability margin resp. a degree of stability/instability. Most probably I have not expressed myself clear enough, sorry for that. Regards |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on May 24th, 2009, 3:48am buddypoor wrote on May 24th, 2009, 3:25am:
Title: Re: How to verify Stability of Total Circuits ? Post by buddypoor on May 24th, 2009, 6:41am pancho_hideboo wrote on May 24th, 2009, 3:48am:
Mmmmh - I am afraid the discussion becomes a bit philosophical now because: For my understanding a phase margin derived from an open-loop analysis gives exactly the additional phase shift to be introduced into this loop in order to make the closed loop unstable. More than that, if the margin is - letīs say - only 30 deg, I know I have to enhance the phase within this loop by additional 30 deg in order to arrive at 60 deg. There is an additional point: Normally, one is in the position to estimate the probability if the margin will decrease to zero or not due to some uncertainties, tolerances or temperature resp aging effects. Now, what is the practical meaning of the margin derived by the method mentioned by you ? What can I do to improve the margin ? Is it possible to estimate if it is sufficient or not ? Interesting Question for my opinion. Regards |
Title: Re: How to verify Stability of Total Circuits ? Post by pancho_hideboo on Jun 15th, 2009, 1:39am buddypoor wrote on May 24th, 2009, 6:41am:
"1+G(s)" type Nyquist Diagram for "Characteristic Polynomial of Matrix A", ΦA(s)=det(s*I-A) is no more than classic control theory. However it is almost impossible to evaluate GM(Gain Margin) and PM(Phase Margin) properly. Generally it is very difficult to grasp proper physical image and meaning in results of modern control theory compared to classic control theory. To my regret, Agilent GoldenGate does not provide any information regarding "Controllability" and "Observabillity" of System under Analysis. I requested enhancements for Agilent. |
Title: Re: How to verify Stability of Total Circuits ? Post by buddypoor on Jun 15th, 2009, 3:12am pancho_hideboo wrote on Jun 15th, 2009, 1:39am:
Thanks for your reply. I completelx agree. Regards LvW PS: I would very much appreciate a comment from your side regarding my two contributions "opamp integrators" in the ANALOG FORUM dated June 11. |
