https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Schematic as stop view in icfb https://designers-guide.org/forum/YaBB.pl?num=1246472227 Message started by Haydar on Jul 1st, 2009, 11:17am |
Title: Schematic as stop view in icfb Post by Haydar on Jul 1st, 2009, 11:17am Hi, I'm setting "schematic" in the stop view list so the netlister doesn't descend into the subckt blocks. This works if I have a single level gates such as a nand. However if I have multiple levels of hierarchy the netlister fails. For example for a single level hierarchy for a NAND gate and with a stop view of schematic I get what I expect even though the pins are missing! The netlister only includes the instantiation line as: // Library name: hkutuk_lib // Cell name: netlist_problem // View name: schematic g0 a9na2n size0W=0.0u size0L=0.0u size1W=0.0u size1L=0.0u but when I use a multilevel hierarchical block the netlister fails with a message like this: Netlist Error: Cannot find any info on instance "i3" in cell-view "hkutuk_lib" "netlist_problem" "schematic" Is there something wrong with the netlister or am I missing something? Thanks, -Haydar |
Title: Re: Schematic as stop view in icfb Post by Andrew Beckett on Jul 10th, 2009, 8:40am As we've been discussing this at http://www.cadence.com/Community/forums/p/12853/18944.aspx#18944 I won't answer it here too... Regards, Andrew. |
