https://designers-guide.org/forum/YaBB.pl Measurements >> Other Measurements >> how to generate a negative voltage during test https://designers-guide.org/forum/YaBB.pl?num=1253501884 Message started by trashbox on Sep 20th, 2009, 7:58pm |
Title: how to generate a negative voltage during test Post by trashbox on Sep 20th, 2009, 7:58pm I need to add a negative voltage on the PCB for my circuit, the average output current is about 80mA. Except the charge pump chip, how can I realize a negative voltage with simple method? Thanks in advance! Trashbox |
Title: Re: how to generate a negative voltage during test Post by loose-electron on Jan 8th, 2010, 1:49pm a separate negative power supply an oscillator generator and an isolation transformer a capacitive charge pump A solar cell and a bright light (just kidding) :P |
Title: Re: how to generate a negative voltage during test Post by love_analog on Apr 20th, 2010, 8:12am You can easily use a negative buck boost. This way it is also easy to change the voltage later on (by changing duty cycle) |
