https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> how to set the vale of output frequency sweep range in pnoise simulation https://designers-guide.org/forum/YaBB.pl?num=1257245734 Message started by bsaqycx on Nov 3rd, 2009, 2:55am |
Title: how to set the vale of output frequency sweep range in pnoise simulation Post by bsaqycx on Nov 3rd, 2009, 2:55am Dear all: I'd like to simulate the jitter of clock slicer ( used to adjust the duty cycle of clock ). When I do the pnoise simulation, I've no idea how to set the vale of output frequency sweep range. When I set the " stop" value to be 2 times clock frequency ( 8MHz) , the outcome seems reasonable ( 5ps ). But when I set the " stop" value to be 1GHz, the jitter turns to be 6us. I've no idea how to choose output frequency sweep range correctly. What's more, when I open " Main Form" I find an option called "tdnoise". What's the meaning of this result? Thank you in advance! |
Title: Re: how to set the vale of output frequency sweep range in pnoise simulation Post by Frank Wiedmann on Nov 3rd, 2009, 5:32am See http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785 and the links given there (http://www.designers-guide.org/Forum/YaBB.pl?num=1092399689/20#20 for the frequency range in tdnoise or jitter analysis). |
Title: Re: how to set the vale of output frequency sweep range in pnoise simulation Post by bsaqycx on Nov 3rd, 2009, 7:27pm Thank you very much for your help! |
Title: Re: how to set the vale of output frequency sweep range in pnoise simulation Post by bsaqycx on Nov 10th, 2009, 10:46pm the frequency of input clock is 4MHz, how should I choose the Stop frequency to get the proper cycle-to-cycle jitter? The results change a lot if the Stop frequency is chose different! |
Title: Re: how to set the vale of output frequency sweep range in pnoise simulation Post by Haward Zhu on Sep 19th, 2010, 11:46pm the same question confused me too |
