https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> how to reduce the 60 Hz power line ripples https://designers-guide.org/forum/YaBB.pl?num=1258235381 Message started by LeonQQ on Nov 14th, 2009, 1:49pm |
Title: how to reduce the 60 Hz power line ripples Post by LeonQQ on Nov 14th, 2009, 1:49pm Hi All, I wonder how to reduce the 60 Hz power line ripples in real measurement? I grounded the inputs of my amplifier, but the output shown on the oscilloscope had a big ripple (around 30 mVpp) mainly 60 Hz freq component. I probed a high-impedance node through a discrete buffer, the buffer output impedance is low (tens of ohms), the oscilloscope input impedance is 1 Mohm. Through all corner simulations my PSRR is not bad at 60 Hz (> 80 dB), and usually op amp PSRR is better at low freq than higher freq. I wonder where usually these 60 Hz ripples would coupled in, from the discrete buffer? I am not sure. Thank you for the help. Leon |
Title: Re: how to reduce the 60 Hz power line ripples Post by pancho_hideboo on Nov 14th, 2009, 10:44pm (1) Observe DC Power Supplier Output by Oscilloscope without connecting DUT. Is there no 60Hz ripple ? (2) Confirm AC Ground of DC Power Supplier and Oscilloscope. How do you feed AC power to these equipments ? (3) Turn off every lights in the room. (4) Use battery instead of DC Power Supplier Condition of AC power feeding and Ground including DUT is very suspicious. |
