https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> USB 2.0 High Speed Current Driver ... https://designers-guide.org/forum/YaBB.pl?num=1261465981 Message started by somisetty on Dec 21st, 2009, 11:13pm |
Title: USB 2.0 High Speed Current Driver ... Post by somisetty on Dec 21st, 2009, 11:13pm Hi, what would be the load for USB 2.0 High Speed Current Driver for simulating the rise and fall times? Thanks |
Title: Re: USB 2.0 High Speed Current Driver ... Post by raja.cedt on Dec 22nd, 2009, 9:21pm hi, where you want to check rise and fall (at the pad?) Thanks, Rajasekhar. |
Title: Re: USB 2.0 High Speed Current Driver ... Post by casual on Mar 27th, 2010, 8:00am normally measure eye diagram at TP2/TP3. The load is from chip to PCB & connector. |
