https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Doubt regarding PNOISE results obtained from Spectre-RF https://designers-guide.org/forum/YaBB.pl?num=1262097621 Message started by shaikh_sarfraz on Dec 29th, 2009, 6:40am |
Title: Doubt regarding PNOISE results obtained from Spectre-RF Post by shaikh_sarfraz on Dec 29th, 2009, 6:40am Hi, What sort of spectral density is obtained when we do Pnoise analysis. Is it power spectral density of phase or is it power spectral density of voltage? Best Regards Sarfraz |
Title: Re: Doubt regarding PNOISE results obtained from Spectre-RF Post by pancho_hideboo on Dec 29th, 2009, 7:09am shaikh_sarfraz wrote on Dec 29th, 2009, 6:40am:
This is true for any vendor's simulator. Just we can decompose this voltage noise to AM and PM noises. That's all. See my appends in the followings. http://www.designers-guide.org/Forum/YaBB.pl?num=1244213153/6#6 http://www.designers-guide.org/Forum/YaBB.pl?num=1260521995 http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395 |
Title: Re: Doubt regarding PNOISE results obtained from Spectre-RF Post by Andrew Beckett on Jan 5th, 2010, 1:27pm See also the discussion in http://www.cadence.com/community/forums/T/14375.aspx - ah, it's the same requestor. Regards, Andrew. |
