https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Problem with ADS MCLIN ! https://designers-guide.org/forum/YaBB.pl?num=1265012932 Message started by kennycs on Feb 1st, 2010, 12:28am |
Title: Problem with ADS MCLIN ! Post by kennycs on Feb 1st, 2010, 12:28am When I use S-parameter simulate with MCLIN(differential lines) in ADS, the result |S11|,|S21| seems wrong. I think |S21| should be monotone decreasing ,But the result shows it is periodic ,I'm confused! Thanks! |
Title: Re: Problem with ADS MCLIN ! Post by pancho_hideboo on Feb 1st, 2010, 1:41am kennycs wrote on Feb 1st, 2010, 12:28am:
Frequency characteristics of lossless line is periodic. Why do you think |S21| decrease monotonically ? Consider |S21| of lossless single line. Does |S21| decrease regarding frequency ? For coupled line, if you pay attention to one line, another line acts as resonator. So periodicity of |S21| is natural. |
Title: Re: Problem with ADS MCLIN ! Post by kennycs on Feb 1st, 2010, 7:12pm pancho_hideboo wrote on Feb 1st, 2010, 1:41am:
Thank you very much, I got the reason. :D |
