https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> ncelab transistion argument https://designers-guide.org/forum/YaBB.pl?num=1270567529 Message started by Rizzo on Apr 6th, 2010, 8:25am |
Title: ncelab transistion argument Post by Rizzo on Apr 6th, 2010, 8:25am Hello. Iam a student working on my diploma thesis and iam reletivily new to analog modeling. Iam to use the ams designer to create a model for an energy supply and verify a module of the supply i built in schematics. This i extract with amsdirect to veriog-ams code. 'This is the therory so far. My tests worked out quit well. I worked myself through most of our designframework. like ADE L, nclog ncelab and ncsim. most of my testcircuits are working so far. Now I need a clock generator. So i used an an example from the designersguide to verilog ams. Code:
my problem ist, that i can compile this with ncvlog -AMS without a problem, but ncelab says, that the transition statement is not allowed in this context ("conditionally-executed statement or in an expression") and that i use a contribution statement and should delete it. Can someone tell me, why the transition statement isnt allowed and how i can create a clk_gen is verilog-A? The best way would be to use the spectre sources (as i understand, ncsim uses for the analog part of the simulation spectre) but until now i wanst able to do that. I could not found a detailed guide how to use the simulator sources in a vams netlist. |
Title: Re: ncelab transistion argument Post by Andrew Beckett on Apr 7th, 2010, 7:38am The problem is that neither the contribution nor the transition would be evaluated at every timestep - and so they would not be defining the appropriate equations or remembering the transitions from each iteration. You also have two contribution statements on the same pair of nodes - these will end up as voltage sources in series. Best thing is to attend a training class on Verilog A or Verilog AMS (Cadence offers these, as I'm sure do others) or read a good book such as http://www.designers-guide.org/Books/#Kundert-2004 Regards, Andrew. |
