Simulators >> Circuit Simulators >> ADS to design and simulate antena( please, help me)
https://designers-guide.org/forum/YaBB.pl?num=1273022317
Message started by hieuphong on May 4th, 2010, 6:18pm
Title: ADS to design and simulate antena( please, help me)
Post by hieuphong on May 4th, 2010, 6:18pm
hi you!
i'm using ADS ( advanced design system) to simulate RF circuit. now, i'm having a problem i need everyboy help me
My problem is" circuit design set rotate phase, combine Hybrid ( 90 degree) and varactor diode to control  phase angle shift  between input and output"
i have been designed it but i want to simulate by ADS with: " vatical axis is angle phase, horizontal axis is capacitance not frequency" please help me.
Title: Re: ADS to design and simulate antena( please, help me)
Post by pancho_hideboo on May 4th, 2010, 8:56pm
I can't find out any design issue in your post.
Your questios are no more than very easy usage of very specific tool.
Do two AC or SP analyses.
(1) AC with dc voltage sweep for varactor alone
(2) AC or SP analysis with dc voltage sweep for phase shifter
You can get capacitance from (1).
You can get phase shift from (2).
Here you can also do (1) in (2) by placing replica varactor for evaluation of capacitance.
Then use "plot_vs()" function.
http://edocs.soco.agilent.com/display/ads2009/plot+vs%28%29
Read all documents of Agilent ADS surely.
The followings are general notes for you.
- Always describe vendor's name which you use as tool or simulator.
- Don't do multiple posts which are same content.
- Don't request source code or behavioral model without any efforts.
- There are many simulators which have analyses called as PSS, PAC and Pnoise.
- Describe in detail with using correct terminologies.
- Warnigns are different from Errors.
- ADS is not name of simulator.
- There is no tool which name is Cadence.
- Don't use Direct Plot of Cadence ADE blindly without knowing definition.
- All gains in Direct Plot of Cadence ADE are "right", "true" and "practical" voltage gain.
- Don't mix up Simulation with Post Processing. They are completely different phase.
- MATLAB are different from Simulink.
- Learn measurements using actual instruments. Not "EDA Tool Play
Post by hieuphong on May 5th, 2010, 4:31am
hi pancho. i sent to you my design file. Please check it.
Now i want to use a voltage to control varactor diode why i have to do.
Mybe when you see my file, You will understand.
Post by pancho_hideboo on May 5th, 2010, 4:41am
It seems you are not familiar with Agilent ADS.
So it seems you can't understand my answers at all.
What you want to do is very easy task in Agilent ADS.
Post by hieuphong on May 5th, 2010, 12:51pm
it's an ADS 2008 update 2. Do you understand my question? Maybe, my english is too bad so you don't know what i wrote
OK. i repeat my problem " i want to design a circuit  that combine between quadrature hybrid and vacator diode. to use diode to control angle phase shift between input and output.the ange  phase shift will change [0:360 degree] when vacator diode change capacitance."
Now i want to simulate by ADS. vatical axis is angle phase shift, horizontal axis is capacitance"
You can see figure
Post by pancho_hideboo on May 6th, 2010, 2:12am
Don't attach such non-valuable figure.
hieuphong wrote on May 5th, 2010, 12:51pm:
I understand your question.
Answer is http://www.designers-guide.org/Forum/YaBB.pl?num=1273022317/1#1
Again, what you want to do is very easy task in Agilent ADS.
This is a special service since you are new comer in this forum.
Maybe you are student.
So discuss such very easy issue with friends or read all documents surely next time.
Post by pancho_hideboo on May 6th, 2010, 2:19am
hieuphong wrote on May 4th, 2010, 6:18pm:
hieuphong wrote on May 5th, 2010, 4:31am:
No varactor or voltage-controlled-capacitor is used in any of "FULL_TK2_020_e343(2).dsn", "hic.dsn" and "thunghiem.dsn".
Maybe you substitute fixed value "CAPQ" for "varactor".
So situation is more easy than "http://www.designers-guide.org/Forum/YaBB.pl?num=1273022317/1#1".
Post by pancho_hideboo on May 6th, 2010, 2:30am
Again read all documents of Agilent ADS surely.
Attached archive include schematic("*.dsn", "*.ael", "*.atf") and "*.dds" files I used.
Post by hieuphong on May 6th, 2010, 1:32pm
thanks for your help, pancho. I have done  my lesson,again. I'm a student in VietNam, the firt time i have used ADS to simulate and design RF circuit,Microwave.
i hope, i will help more and more
Good luck to you, Pancho.
