https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Any built-in element in ADS/MATLAB for doing de-embedding https://designers-guide.org/forum/YaBB.pl?num=1281496812 Message started by DoYouLinux on Aug 10th, 2010, 8:20pm |
Title: Any built-in element in ADS/MATLAB for doing de-embedding Post by DoYouLinux on Aug 10th, 2010, 8:20pm Hi all, I am just wondering that, since the process (algorithms, equations) of some de-embedding or calibration techniques such as TRL, LRM, ect. are well defined, have they been implemented as standard elements in ADS or standard functions in MATLAB (RF toolbox, maybe) ? For example, in ADS, if this feature were to exist, I just bring my measured S parameters of DUT (including results from test fixture), thru, reflect and line and then insert these S2P data in ADS. Then, there should be a block or function to take care of these S2P data according to a de-embedding de-embedding technique. Then this element will calculate the S parameter of the DUT directly. This would be fantastic ;) Do these feature really exist ? Thank you in advance, DYL |
Title: Re: Any built-in element in ADS/MATLAB for doing de-embedding Post by pancho_hideboo on Aug 10th, 2010, 8:43pm See http://www.designers-guide.org/Forum/YaBB.pl?num=1245915183/2#2 |
Title: Re: Any built-in element in ADS/MATLAB for doing de-embedding Post by DoYouLinux on Sep 14th, 2010, 5:54pm Sorry for my late response. Very busy this time. Thank you very much, pancho_hideboo. I am following the information. DYL :) |
