Simulators >> Circuit Simulators >> please specify a result name
https://designers-guide.org/forum/YaBB.pl?num=1283235399
Message started by wunderkind on Aug 30th, 2010, 11:16pm
Title: please specify a result name
Post by wunderkind on Aug 30th, 2010, 11:16pm
I want to save the transient value in a text file using ocean script. The command is ocnprint. The sentence is as followed:
ocnprint(?output "fft.txt" v("/outp"))
The net of the output is named outp.
But when i run the sript after the transient simulation is finished, it shows "Please specify a result name")
I am just wondering how to solve this problem.
Thanks
Title: Re: please specify a result name
Post by pancho_hideboo on Aug 31st, 2010, 4:46am
Use "openResults()" and "selectResult()".
Post by wunderkind on Aug 31st, 2010, 10:18pm
Thank you
