https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Virtuoso license auto check in https://designers-guide.org/forum/YaBB.pl?num=1286955435 Message started by Prashant Babu on Oct 13th, 2010, 12:37am |
Title: Virtuoso license auto check in Post by Prashant Babu on Oct 13th, 2010, 12:37am Hi people, Can anybody please tell me if there is a way to auto check-in Virtuoso Schematic/Layout Editor license when not being actively used? I know of a way to do that with Spectre i.e. envSetVal("spectre.envOpts" "controlMode" 'string "batch") but is it possible with other licenses too? Thanks for your time. Regards, Prashant |
Title: Re: Virtuoso license auto check in Post by Andrew Beckett on Jan 3rd, 2011, 12:04am Look in <instDir>/doc/license/license.pdf and search for the word "TIMEOUT". This describes how to set up license timeouts on the license server. The license can then be clawed back after a period of non-use. Note that when you start using it again in the session which has timed out, it will try to re-check out the license again. The license should also get auto checked in when you close all schematic windows in Virtuoso. Regards, Andrew. |
