https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> sensitivity analysis in Ocean script https://designers-guide.org/forum/YaBB.pl?num=1292191819 Message started by c1000 on Dec 12th, 2010, 2:10pm |
Title: sensitivity analysis in Ocean script Post by c1000 on Dec 12th, 2010, 2:10pm In the ocean script, I need to simulate the sensitivity of ids to l (Leff) with respect to vds, vgs and vbs. For ids table, I used **************************************************** analysis( 'dc ?saveOppoint t ) paramAnalysis("Vb" ?start Vground ?stop -Vsupply ?step -0.1 paramAnalysis( "Vg" ?start Vground ?stop Vsupply ?step 0.05 paramAnalysis( "Vd" ?start Vground ?stop Vsupply ?step 0.05 ) ) ) paramRun() selectResults('dcOpInfo) idsAll = pv("n1" "ids") ***************************************************** then how to 'sens?? I checked documents, it seems 'sens is only valid for dc not paramAnalysis. do I need to sweep vb,vg and vg in the script and simulate? Then the other problem pops out. if I use the following script for sensitivity analysis, **************************************************** analysis( 'sens ?analyses_list "dc" ?output_variables_list "n1:ids" ?design_parameters_list "l" ) dc( "Vg" "dc" 0.00 0.05 0.10 ) run() selectResults('sens) ******************************************************* then how to save and display the sensitivities with respect to vds,vgs and vbs?? I used to use pv() to save ids values with respect to terminal voltages. but in .sens, the output is "n1:ids,n1:l", then I don't know how to use pv() and whether I should use pv(). how to do that? |
Title: Re: sensitivity analysis in Ocean script Post by Andrew Beckett on Jan 2nd, 2011, 9:22am You don't need to do a parametric analysis to do a sensitivity analysis. Assuming you have a source called "vds" and "vgs" in your schematic, the following OCEAN script can be used: Code:
Then afterwards, do: Code:
The ?output_list is referencing the ids parameter of the transistor you want to measure the sensitivity to. ADE always produces a sensitivity analysis to all instance and model parameters (there's no way to be selective about it, unfortunately, despite the fact that this is supported in spectre). The results are presented in terms of pairs of output parameter to input parameter names - in this case I'm checking the sensitivity to the dc parameter on the two voltage sources. Best Regards, Andrew. |
Title: Re: sensitivity analysis in Ocean script Post by c1000 on Jan 3rd, 2011, 6:46am Thanks a lot!!! |
