https://designers-guide.org/forum/YaBB.pl Simulators >> Logic Simulators >> Generating liberty (.lib) files for analog blocks. https://designers-guide.org/forum/YaBB.pl?num=1292958243 Message started by BillH on Dec 21st, 2010, 11:04am |
Title: Generating liberty (.lib) files for analog blocks. Post by BillH on Dec 21st, 2010, 11:04am What is the best way to generate liberty (.lib) format timing files for an analog block (e.g. PLL) to be used in a digital top level integration flow? So far, we have basically used a combination of legacy liberty files and hand-editting new information. But I was wondering if there are standard tools or flows used for this step? Thanks. |
Title: Re: Generating liberty (.lib) files for analog blocks. Post by haykp on Dec 23rd, 2010, 12:12am You can use synopsys libertyNCX tool to generate the lib file. The tool mainly needs extracted input, model files and hspice simulator access. |
Title: Re: Generating liberty (.lib) files for analog blocks. Post by Andrew Beckett on Jan 2nd, 2011, 12:38pm There is also a capability in DCM (part of ADE GXL) in Cadence's IC61 release which can help with generation of .lib for mixed signal blocks. Best Regards, Andrew. |
