https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Measure total determinisitic jitter in Calculator https://designers-guide.org/forum/YaBB.pl?num=1293197122 Message started by ywguo on Dec 24th, 2010, 5:25am |
Title: Measure total determinisitic jitter in Calculator Post by ywguo on Dec 24th, 2010, 5:25am Hi Guy, Is there any function in calculator that can be used to measure total deterministic jitter? To measure the total jitter, including DCD and ISI, a random serial data is applied in the test bench. The period_jitter function is define as Returns a waveform representing the deviation from the average period. It is fine to measure the jitter of a clock, but not for a random serial data. Any comments are appreciated. Yawei |
Title: Re: Measure total determinisitic jitter in Calculator Post by Andrew Beckett on Jan 2nd, 2011, 2:19am Hi Yawei, You may find this function (abEyeCross) useful for this: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11395772 Other relevant/related solutions: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11018920 http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11564054 Best Regards, Andrew. |
Title: Re: Measure total determinisitic jitter in Calculator Post by ywguo on Jan 18th, 2011, 5:45pm Thank you very much, Andrew. |
