https://designers-guide.org/forum/YaBB.pl General >> Opportunities >> Lead Developer, Extraction and Timing Analysis https://designers-guide.org/forum/YaBB.pl?num=1298429171 Message started by latha on Feb 22nd, 2011, 6:46pm |
Title: Lead Developer, Extraction and Timing Analysis Post by latha on Feb 22nd, 2011, 6:46pm Hi All, We are looking for:Lead Developer, Extraction and Timing Analysis This position is expected to be highly experienced (8-10 years). The experience can be in one or more of the following three areas (in order of preference): (i) EDA methodology/flow development (ii) EDA vendor AE (iii) Digital design engineer. He/she should have expert working knowledge of the design flow and relevant EDA tools (Cadence expertise preferred) in the domain. Should have expertise in signoff quality extraction. This includes generation of RC data/cap tables using field solver utilities provided by vendors. This also includes ensuring required silicon accuracy and correlation with implementation tools. Must have expert level understanding and working knowledge of static timing analysis including concepts such as modes, corners and OCV. Should be very familiar with native tool constraints specification formats as well as SDC Should have worked on timing analysis of production designs to enable good understanding of sound methodology. Must understand crosstalk analysis (both impact on delay as well as injection of glitches). Cadence ETS experience preferred. Tools: Preferable to have work experience with Cadence tools, but experience with other tools too would be considered. Scripting and software languages: Perl / Tcl / C++ pls send your cv's to hr@callidasoft.com Thanks |
