Design >> High-Speed I/O Design >> data sampler vs edge sampler
https://designers-guide.org/forum/YaBB.pl?num=1305444346
Message started by casual on May 15th, 2011, 12:25am
Title: data sampler vs edge sampler
Post by casual on May 15th, 2011, 12:25am
what are the differences between them and their pros and cons?
Title: Re: data sampler vs edge sampler
Post by loose-electron on May 16th, 2011, 5:43pm
there are a bunch of different detection methods out there, depending on how degenrated your signal gets in the transmission medium.
Can you be more specific with the question?
Post by casual on May 17th, 2011, 6:03am
data sampler and edge sampler are the sense-amp based regeneration flip-flops. Interested to know what are the differences between them.
Want to use it at the high-speed IO.
Post by Chhotu on Jul 6th, 2011, 4:38am
Basically, there are no difference between Data and edge samples as far as design is concerned . Only , data sampler is clocked with data clock (q clock) and edge sampler is clocked with edge clock (i clock).
-Chhotu
Post by casual on Jul 7th, 2011, 6:09pm
thx :)
