https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> limit in spectreMDL outputs "*.measure" files.... https://designers-guide.org/forum/YaBB.pl?num=1308227250 Message started by Evgenii on Jun 16th, 2011, 5:27am |
Title: limit in spectreMDL outputs "*.measure" files.... Post by Evgenii on Jun 16th, 2011, 5:27am Hi! I use "foreach" function in spectreMDL script, for example: foreach VL from {1.65, 1.95, 2.3, 2.7, 3, 3.6} { foreach VCC from {2.3, 2.7, 3, 3.6, 4.5, 5.5} { run delay as typ_25 } } In my ".mdl" file i need repeat this construction for many temperature and many corners. i do this... But output ".measure" file do not contain all measurements. Output range of measurements in some places in file looks clipped.... May be "foreach" has memory limit or something else... Thanks! :) ps version - spectre (ver. 5.10.41.020608 -- 06 Feb 2008). and for run simulation i use: - $spectremdl -tab -b *.mdl |
