Simulators >> Circuit Simulators >> Preamplifier noise specifications
https://designers-guide.org/forum/YaBB.pl?num=1311143483
Message started by nishanth on Jul 19th, 2011, 11:31pm
Title: Preamplifier noise specifications
Post by nishanth on Jul 19th, 2011, 11:31pm
Hai,
I want to calculate the following two quantities for my preamplifier with cadence tool. Can anybody give me the procedure?
1. Total input referred noise voltage Power Spectral Density @1Hz & @100Hz.
2. Total input referred r.m.s noise voltage (1 Hz - 100 Hz)
Suggest me acceptable range of the above two quantities for low noise low power applications
Thanks in advance,
Nishanth P.V
Title: Re: Preamplifier noise specifications
Post by ywguo on Aug 13th, 2011, 6:45pm
If you had run noise analysis in ADE, the input referred noise power spectral density is there.
Then integrate the power spectral density from 1 Hz to 100 Hz, you get the total input referred r.m.s noise voltage (1 Hz - 100 Hz)
At last, I don't know what is acceptable range. You should ask your customer if you have, otherwise ask who is in charge of the project.
Yawei
