https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> extracting a netlist from gds https://designers-guide.org/forum/YaBB.pl?num=1313084405 Message started by vp1953 on Aug 11th, 2011, 10:40am |
Title: extracting a netlist from gds Post by vp1953 on Aug 11th, 2011, 10:40am I want to extract a netlist from gds. Is there anyway this can be done using Cadence assura. Thank you. |
Title: Re: extracting a netlist from gds Post by ywguo on Aug 13th, 2011, 6:35pm Sure you can do it with Assura. Do you have any experience in Assura? If the tool is installed in your environment. Choose Assura --> Run QRC in Virtuoso layout editor. |
