https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> Generating a signal (a VHDL description) with a well-defined frequency in a FPGA https://designers-guide.org/forum/YaBB.pl?num=1320555672 Message started by issam on Nov 5th, 2011, 10:01pm |
Title: Generating a signal (a VHDL description) with a well-defined frequency in a FPGA Post by issam on Nov 5th, 2011, 10:01pm Hello, In fact, I'm working on a project that aims to put a communication platform to interact with hydrogen sensor wirelessly. The platform consists of an evaluation board from Xilinx ML505 (on which there is a Virtex 5) which will implement the baseband digital processing and another board (Software Defined Radio) for the analog front end that includes the blocks needed (modulator / demodulator, filter, LNA, PA, local oscillator) to communicate on the UHF band (900 MHz). The platform requires a 12-bit DAC and an ADC 12-bit to adapt the two boards. So I need help to generate a baseband signal (VHDL description) with a defined frequency, otherwise, I have trouble to describe the signal generator in VHDL |
