https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Jitter estimation on synchronous counter https://designers-guide.org/forum/YaBB.pl?num=1320886468 Message started by thechopper on Nov 9th, 2011, 4:54pm |
Title: Jitter estimation on synchronous counter Post by thechopper on Nov 9th, 2011, 4:54pm Dear colleagues, Assuming I know how much jitter my reference clock has, I need to estimate de jitter of synchronous counter of N stages. If the reference clock jitter is jck my gut feeling is that the total jitter should be jck*√N (assuming uncorrelated jitter between stages). Is this correct? Any other considerations (or references)? Thanks Tosei |
Title: Re: Jitter estimation on synchronous counter Post by rajkumar palwai on Nov 9th, 2011, 8:28pm Tosei, For any flip-flop, the inherent noise in the devices also add jitter at the o/p. So, if the ref clk has jitter of 'jck' and the device noise add a jitter of 'jdn', then the total jitter at the o/p would be rms average of jck & jdn. For synchronous dividers, jitter doesn' accumulate between stages. Because the jitter at the o/p of the final flop just depends on the jck and its own noise at that time. |
Title: Re: Jitter estimation on synchronous counter Post by rajkumar palwai on Nov 9th, 2011, 8:29pm Jitter accumulation happens in ripple counters where, each stage jitter affects the next stage transition. |
