https://designers-guide.org/forum/YaBB.pl Simulators >> Timing Simulators >> How to make VCO start to oscillate in ultrasim? https://designers-guide.org/forum/YaBB.pl?num=1325825830 Message started by ahhfyz on Jan 5th, 2012, 8:57pm |
Title: How to make VCO start to oscillate in ultrasim? Post by ahhfyz on Jan 5th, 2012, 8:57pm Hi, everyone! I am a beginner in ultrasim. Now I try to simulate a vco in ultrasim. sim_mode is set to "a(analog)", and speed is "1", but it cannot start to oscillate. I guess it is a tolerence problem, but don't know how to further set tol. Regards! Yang |
Title: Re: How to make VCO start to oscillate in ultrasim? Post by raja.cedt on Jan 6th, 2012, 2:06am you have to use initial condition in ultrasim as well |
Title: Re: How to make VCO start to oscillate in ultrasim? Post by weber8722 on Jan 10th, 2012, 5:50am Hi, I would add a little vpwl or ipwl source to kick-start the oscillator. This should work independent to any simulator (hspice, spectre, ultrasim, ams-designer,...). Bye Stephan |
Title: Re: How to make VCO start to oscillate in ultrasim? Post by raja.cedt on Jan 12th, 2012, 10:07am hello Stephan, i guess in altrasim you don't have pulse input i guess. Thanks, Raj. |
Title: Re: How to make VCO start to oscillate in ultrasim? Post by ahhfyz on Jan 12th, 2012, 10:39pm weber8722 wrote on Jan 10th, 2012, 5:50am:
Setting "initial condition" can kick-start the oscillator, but ipwl fails. |
