https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> How to find the Phase Noise for the DIVIDER https://designers-guide.org/forum/YaBB.pl?num=1332734512 Message started by Ricky Chen on Mar 25th, 2012, 9:01pm |
Title: How to find the Phase Noise for the DIVIDER Post by Ricky Chen on Mar 25th, 2012, 9:01pm Dear all, I want to simulate the phase noise of my divider which take input differential clock source (ideal). Some phase recombinations circuits after the divider give me multiple phase outputs. I want to see the phase noise of each phase output Can any body tell how can I do the phase noise simulation of my divider. ( please point to any suitable documents) I want to do following simulations with the divider 1) simulate without any phase noise in the clock 2) simulate with certain amount phase noise in the clock 3) Lastly, I want to make some trasnsistors of the divider NOISELESS and then do the phase noise simulation I could make the flicker noise of desired MOS transistors zero but How can I make their thermal NOISe zero. |
Title: Re: How to find the Phase Noise for the DIVIDER Post by Frank Wiedmann on Mar 26th, 2012, 2:31am I'm not sure if this is possible. However, if you are using Cadence, you should be able to get all the information you need with a single simulation run by using the Noise Summary feature of ADE. |
Title: Re: How to find the Phase Noise for the DIVIDER Post by Frank Wiedmann on Mar 28th, 2012, 5:03am Andrew Beckett has just pointed out at http://www.cadence.com/community/forums/T/22011.aspx that it is in fact possible in Spectre to turn off or on the noise of specified devices. |
