https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> BOOST "DUTY CYCLE" ISSUE https://designers-guide.org/forum/YaBB.pl?num=1352019281 Message started by AnilReddy on Nov 4th, 2012, 1:54am |
Title: BOOST "DUTY CYCLE" ISSUE Post by AnilReddy on Nov 4th, 2012, 1:54am Hi all, I want to intuitively understand why the "Duty" in a typical inductor-based DC-DC BOOST converter depends "quadratically" on the parameters like Output Voltage, Input Voltage, Losses..etc... Mathematically, it is clear to me. But, Why should there be a second-order dependency in this converter, unlike in BUCK Converter? Thank you.. |
Title: Re: BOOST "DUTY CYCLE" ISSUE Post by yuvan on May 6th, 2013, 4:21am I guess intuitively the average current supplied to the output is a strong function of the duty. And same is the case for the 'equivalent resistance' offered by the inductor. So, the quadratic relation comes. Please correct me if I'm wrong. |
Title: Re: BOOST "DUTY CYCLE" ISSUE Post by AnilReddy on May 8th, 2013, 9:18am Hi Yuvan, Thanks for the reply. Anyways, i didn't understand what you were trying to say. Can you please elaborate a bit? Thanks... Regards, Anil Reddy |
