https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Voltage Conversion Gain Mixer https://designers-guide.org/forum/YaBB.pl?num=1354003417 Message started by DDC on Nov 27th, 2012, 12:03am |
Title: Voltage Conversion Gain Mixer Post by DDC on Nov 27th, 2012, 12:03am Hello, I want to measure the voltage conversion gain of my gilbert cell downconversion mixer (frf = 2.4GHz, flo = 2.34GHz). I think I can only measure the power conversion gain with a spectrum analyzer. Is there an equation to calculate the vcg from s-parameters or an other method to evaluate this ? Thanks for response. |
Title: Re: Voltage Conversion Gain Mixer Post by rfidea on Nov 27th, 2012, 11:35am Use the relationship between voltage and power, P = Vp^2/(2R). So, is your source resistance is RS and the load resistance is RL the voltage gain is Gv = Vout/Vin = sqrt(Pout*2*RL)/sqrt(Pin*2*RS) = sqrt(Gp)*sqrt(RL/RS) or in decibel Gv,dB = 20*log(Gv) = 10*log(Gp)*10log(RL/RS) = Gp,dB*10log(RL/RS) Usually both your signal source and spectrum analyser is 50 ohm. Is your inputs and outputs designed for handling that? |
