https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> Spectre Netlist error https://designers-guide.org/forum/YaBB.pl?num=1360239593 Message started by neuro11 on Feb 7th, 2013, 4:19am |
Title: Spectre Netlist error Post by neuro11 on Feb 7th, 2013, 4:19am I have designed an inverter using nmos4 and pmos4(NCSU_Analog_Parts) and edited the width and length with varriable Wid and Len. After changing the Drain Diffusion Area value becomes Wid*2.5*iPar("MinL") as it should be. However every time i try Netlist and Run, i get the following errors "input.scs" 17 : Function 'iPar' is undefined or is used recursively "input.scs" 17 : Function 'iPar' is undefined or is used recursively "input.scs" 18 : Function 'iPar' is undefined or is used recursivelyl "input.scs" 18 : Function 'iPar' is undefined or is used recursively "input.scs" 20 : Function 'iPar' is undefined or is used recursively "input.scs" 20 : Function 'iPar' is undefined or is used recursively "input.scs" 20 : Function 'iPar' is undefined or is used recursively "input.scs" 21 : Function 'iPar' is undefined or is used recursively I tried to edit CDF parameter for nmos4 and pmos4 by trying to edit paramenter MinL(assuming this is source of error) as parseasCEL = yes and parseasNumber = yes. But it did not improve a bit. Please tell me what to do. Note : i was following this tutorial and did exactly what is said but same errors. http://www.ece.virginia.edu/~mrs8n/c...tutorial4.html |
Title: Re: Spectre Netlist error Post by boe on Feb 13th, 2013, 5:30am Neuro11, you probably mean pPar ... - B O E |
Title: Re: Spectre Netlist error Post by neuro11 on Feb 19th, 2013, 5:33am No, i meant iPar(). I could solve the problem by setting up the following environment varriable. setenv CDS_Netlisting_Mode Analog |
