Modeling >> Semiconductor Devices >> Hspice and verilog A
https://designers-guide.org/forum/YaBB.pl?num=1362862096
Message started by conix33 on Mar 9th, 2013, 12:48pm
Title: Hspice and verilog A
Post by conix33 on Mar 9th, 2013, 12:48pm
Hello,
I am new to the forum and to the modeling world. I am trying to understand how to combine Hspice and verilog . I would like to model  a OTFT from a model from Hspice. I am at the planning stage still.
I read you can modify a model using Verilog A but I was not able to find how to do it. Please I have some questions I need some answers:
- Can someone guide me how to find those info?
- Can we modify the equations in the file (and rename it to something else) by using Verilog A?
- Are there some OTFT verilog code to use and modify?
I appreciate any help.
Thank you
Title: Re: Hspice and verilog A
Post by Geoffrey_Coram on Mar 11th, 2013, 11:42am
Your first task will be to find a Verilog-A description of an OTFT (I'm not familiar with the acronym).  Do you know of any university research groups working on OTFT?  You should check their web sites and/or publications.
Verilog-A is a language; your second question doesn't really make sense -- you'll modify the equations in the file using a text editor.
