https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Analog simulation timescale is off from actual simulation time https://designers-guide.org/forum/YaBB.pl?num=1363773850 Message started by allannogueras on Mar 20th, 2013, 3:04am |
Title: Analog simulation timescale is off from actual simulation time Post by allannogueras on Mar 20th, 2013, 3:04am Hi, Im seeing a discrepancy between the time scale which is shown for analog signals in simvision compared with the actual time I see the sim have reached in the simulation.log. The factor is 50000. 5us in simulation.log is shown as 50ms in simvision. When digital signals are added it sais "No value available". This is because the digital and analog is on two different time scales, the analog one being the one that is off. When analog signals are deleted and the "=" x-axis autoscale is pressed I can see that the digital signals timescale match the simulation.log time scale. In my AMS simulaton Im using transistor level, veriloga and verilogAMS and Im using APS as analog solver but have seen the problem also with Spectre as a solver. Have anyone seen this before ? Allan |
