https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> VerilogA apply transient final conditions to AC/noise analysis https://designers-guide.org/forum/YaBB.pl?num=1371739788 Message started by anamania on Jun 20th, 2013, 7:49am |
Title: VerilogA apply transient final conditions to AC/noise analysis Post by anamania on Jun 20th, 2013, 7:49am Hi, I have built a VerilogA module that is the AGC for an analog PGA. At the end of transient analysis, the module sets the gain of the PGA so that the output swing settles to a target value whatever the input swing is. How do I apply this gain, says 5 bit control, to subsequent AC & noise analysis? I want to complete all analysis in one simulation. Thanks. |
Title: Re: VerilogA apply transient final conditions to AC/noise analysis Post by Ken Kundert on Jun 21st, 2013, 6:24am Try setting restart=no on the AC analysis, and make sure it is run after the transient analysis. -Ken |
Title: Re: VerilogA apply transient final conditions to AC/noise analysis Post by weber8722 on Mar 1st, 2015, 11:06am Hi Ken, can you give a short example spectre netlist. I think this question is often asked. In Cadence I typically solve the problem with ADEXL and calcVal, but a pure spectre solution would be much more elegant! Bye Stephan |
Title: Re: VerilogA apply transient final conditions to AC/noise analysis Post by Ken Kundert on Mar 1st, 2015, 12:01pm Code:
