https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> psub_StampErrorFloat- Assura LVS https://designers-guide.org/forum/YaBB.pl?num=1372231677 Message started by aki on Jun 26th, 2013, 12:27am |
Title: psub_StampErrorFloat- Assura LVS Post by aki on Jun 26th, 2013, 12:27am Please Help!! I am working on a low noise amplifer (LNA). In the schematic I used rplpoly_rf resistors of TSMC foundary. I generated the layout from Tools-> Design synthesis -> Layout XL. My DRC was cleared and LVS as well. However, Error Layer Window (ELW) popped up and pointing to every resistor that "psub_StampErrorFloat". I have no idea how to solve it. Could you please help me to solve this? Thank you so much. |
Title: Re: psub_StampErrorFloat- Assura LVS Post by purplewolf on Jun 26th, 2013, 3:39am Either your psub is floating or you have to draw its layers by yourself in layout and then connect it to ground. |
Title: Re: psub_StampErrorFloat- Assura LVS Post by bernd on Jul 1st, 2013, 3:52am Your “rppoly_rf” resistor is probably a 3 terminal resistor which needs to be connected with the 3rd terminal to PWell or Psub. For some cases VXL cannot handle and does not recognize such connections automatically. Check if you need a 3rd connection to PWell or Psub with the resistor and if this connection exist in your layout. * |
