https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Spice from Verilog using V2LVS command in Calibre (need to simulate) https://designers-guide.org/forum/YaBB.pl?num=1374684842 Message started by ic_engr on Jul 24th, 2013, 9:54am |
Title: Spice from Verilog using V2LVS command in Calibre (need to simulate) Post by ic_engr on Jul 24th, 2013, 9:54am Hello I have a diigital GDS. I used 'v2lvs' command in Calibre to get the spice generated to perform LVS. All went okay. I now want to perform simulation in Cadence in spectre. To do this, I converted the spice file using 'spp -convert ... and got the spectre file .scs. When I simulated now, its complaining about "Unexpected equals "="/ Expected end of line".. this is happpening since the file has port assignments like a=adc_bit<0>. it seems it wants me to put the net into double quotes. Any suggestions why ? ic_engr |
