https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> renaming for cells hierarchically in Virtuoso https://designers-guide.org/forum/YaBB.pl?num=1375287497 Message started by ic_engr on Jul 31st, 2013, 9:18am |
Title: renaming for cells hierarchically in Virtuoso Post by ic_engr on Jul 31st, 2013, 9:18am Does anyone know if one can rename cells in a library hierarchical using top cell. so if top cell name is: sensor_rev I want to rename by adding: n1_sensor_rev hiearchically so that all cells under sensor_rev are renamed to n1_sensor_rev. Regards ic_engr |
Title: Re: renaming for cells hierarchically in Virtuoso Post by bernd on Aug 8th, 2013, 1:22am You can do this with SKILL, using the cdsCopy functions which are prefixed with ccp*. Unfortunately I don’t have some sample code avaialbel. * |
