https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Entry Tools >> third party tool integration into cadence virtuoso IC610 https://designers-guide.org/forum/YaBB.pl?num=1376234238 Message started by cmos on Aug 11th, 2013, 8:17am |
Title: third party tool integration into cadence virtuoso IC610 Post by cmos on Aug 11th, 2013, 8:17am how can one integrate third party spice simulator like ngspice into cadence IC610? |
Title: Re: third party tool integration into cadence virtuoso IC610 Post by Holger on Nov 5th, 2013, 3:48am please have a look at http://sourceforge.net/projects/imepspiceinterface/ |
Title: Re: third party tool integration into cadence virtuoso IC610 Post by Andrew Beckett on Dec 27th, 2013, 3:14am For details on interfacing a simulator into the Virtuoso Analog Design Environment, you should contact Cadence. You'd need the "OASIS" product, but also you'd need to request the documentation and support for doing such an integration. Because it's not an everyday occurrence, Cadence tends to have a dedicated channel for support requests when doing such an integration. I'd suggest starting by contacting http://support.cadence.com Regards, Andrew. |
