https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> how to create config view and simulate verilog-AMS code https://designers-guide.org/forum/YaBB.pl?num=1376564128 Message started by susona on Aug 15th, 2013, 3:55am |
Title: how to create config view and simulate verilog-AMS code Post by susona on Aug 15th, 2013, 3:55am hai all I am new to use AMS. presently we equipped with Cadence IC614 dfII enivronment. i wanted to code SAR ADC in verilog-AMS so before that i just taken the verilog-AMS code listing 12 from this forum and try to simulate it but i am getting errors in the simulation. i used ADE and try to simulate then also i am getting the errors so can any one tell me how to run verilog-AMS code and test bench using virtuoso ADE the other thing is can we attach verilog-ams to a technology file like 65nm or 180nm technology how to get the power estimation from the verilog-AMS code i am reading the help notes and trying but not able to solve errors if any one can help thanks in advance Regards Susona |
Title: Re: how to create config view and simulate verilog-AMS code Post by susona on Aug 15th, 2013, 9:06pm please some body reply me how to do that |
Title: Re: how to create config view and simulate verilog-AMS code Post by visbi on Aug 19th, 2013, 3:40pm First create the schematic (any other view) from Library Manger. Then in the same file again create config view and select Hierarchy in Open with. Then use the template of AMS. In view select the schematic. Regards Visbi |
Title: Re: how to create config view and simulate verilog-AMS code Post by susona on Aug 19th, 2013, 8:24pm can you explain how to attach technolgy file to verilog -ams code and also to calulate the power consumption for the behavioral verilog-ams code |
Title: Re: how to create config view and simulate verilog-AMS code Post by sheldon on Nov 9th, 2013, 4:22am Susona, When creating library for a purely behavioral modeling purposes, a technology file is not required. You can select none. Sheldon |
Title: Re: how to create config view and simulate verilog-AMS code Post by girishnani on May 1st, 2014, 2:48am hello, i have done all these steps config. and everything.. i was strucked at connecting rules when i add ams setup it doesn;'t show any connecting rules. how to add connecting rules. without those rules it is showing error. please help me. |
Title: Re: how to create config view and simulate verilog-AMS code Post by boe on May 7th, 2014, 8:16am Girishnani, you should start with reading the relevant tutorials. The connect rules should be installed and included in the lib list. - B O E |
