https://designers-guide.org/forum/YaBB.pl Analog Verification >> Analog Functional Verification >> Module access to instance name https://designers-guide.org/forum/YaBB.pl?num=1380753001 Message started by InTheMiddle on Oct 2nd, 2013, 3:30pm |
Title: Module access to instance name Post by InTheMiddle on Oct 2nd, 2013, 3:30pm Is there a way for the module to access it's instance name and display in the standard output? Thanks in advance. Regards, InTheMiddle |
Title: Re: Module access to instance name Post by Andrew Beckett on Dec 27th, 2013, 1:38pm In Verilog (or Verilog-AMS) you can use: $strobe("My name is %M"); to do this. Regards, Andrew. |
