https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> controllable value https://designers-guide.org/forum/YaBB.pl?num=1382614128 Message started by schaedel on Oct 24th, 2013, 4:28am |
Title: controllable value Post by schaedel on Oct 24th, 2013, 4:28am Hi, its a long time ago, when i had to use SPICE in school. I WAS able to do things like this. I remember that it wasn't very difficult. For Simulation i want to control a value (i.e. capacity or resitance) with another input-signal. the paths should be independent. there should only be a control-input (two terminals) an two terminals where between the resistor/capacitor with the controlled value gets connected. shame on me... everything is forgotten :-[ Thank you for your Help. |
Title: Re: controllable value Post by Andrew Beckett on Dec 27th, 2013, 4:55am This probably depends a bit on the simulator you're using, but spectre has a parameter type on its vccs component. You can make the controlled source a voltage controlled resistor or a voltage controlled capacitor (for example). See spectre -h vccs for more detail. Other SPICE simulators also support similar controlled resistors or capacitors, from memory. Regards, Andrew. |
