Modeling >> Transmission Lines and Other Distributed Devices >> Microstrip Lines
https://designers-guide.org/forum/YaBB.pl?num=1385537272
Message started by smwk on Nov 26th, 2013, 11:27pm
Title: Microstrip Lines
Post by smwk on Nov 26th, 2013, 11:27pm
Hi
I want to make the layout of test circuit given in the attached image using microstriplines. The attached image shows some circled part of layout. I want to ask that what does it show?
Also tell me how to use the RFC1 AND RFC2(specifications given in the datasheet) in ADS while making the layout so that I can simulate the final layout? or can I use some inductors in ADS at the place of RFC's?How to calculate the value of those inductors?
