Design >> RF Design >> RF Baseband filter with 100MHz-1GHz bandwidth
https://designers-guide.org/forum/YaBB.pl?num=1387269471
Message started by Pravesh Kumar Saini on Dec 17th, 2013, 12:37am
Title: RF Baseband filter with 100MHz-1GHz bandwidth
Post by Pravesh Kumar Saini on Dec 17th, 2013, 12:37am
1. What kind of implementation for a low pass filter having programmable bandwith from 100MHz-1GHz should be chosen to meet this bandwidth spec. for wireless communication.
2. What If the type of filter is BPF with 2GHz centre frequency and same programmable bandwidth as that of LPF in #1.
Title: Re: RF Baseband filter with 100MHz-1GHz bandwidth
Post by loose-electron on Jan 3rd, 2014, 2:50am
Lots more details needed.
Post by LazyDesigner on Aug 23rd, 2015, 8:51pm
Hello,
If we talk about LPF then OIP3=15dBm, NF=15dB, what else spec you want for this?
Regards,
Pravesh
